g-code problem on Anet a8
gui-rider
Posted · g-code problem on Anet a8
Hi guys,
I'm using cura 3.2.1 on my anet a8 and I'm having problems with my gcode. Because of the udapte (I think it's because of that), there is 2 gcode section, one for the machine (start/end gcode) and one for the extruder (extruder start/end gcode), the problem is that when I try to find a g-code for my printer on the internet I only find one (start/end) g-code, it's not separated in two section and I don't know what to put in each section
Here is my start gcode :
G21 ;metric values
G90 ;absolute positioning
M82 ;set extruder to absolute mode
M107 ;start with the fan off
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
G1 Z15.0 F3600 ;move the platform down 15mm
G1 F3600
M117 Printing...
end :
M104 S0 ;extruder heater off
M140 S0 ;heated bed heater off (if you have it)
G91 ;relative positioning
G1 E-1 F300 ;retract the filament a bit before lifting
the nozzle, to release some of the pressure
G1 Z+0.5 E-5 X-20 Y-20 ;move Z up a bit and retract
filament even more
G28 X0 Y0 ;move X/Y to min endstops, so the head
is out of the way
G1 X0 Y+180 F3600 ;move buildplate forward
M84 ;steppers off
What should I put in both section ?
At this point, what my printer does is home, start the skirt, randomly goes at the Y axes end, keep doing the skirt and randomly goes at the X axes end..
Can someone please help me ?
    • 1 month later...
    • 3 months later...
        How to Enter
        Design an Ornament
          Entering a new design
        Entering an existing design
        Winning designs should:
        Be original Creations
        Good luck 🎉
        • 1 reply
        • 12 replies
