HI Gr5,
thank you for your reply. I will definitely try with different wall thickness.
I went back to check the print layer of the existing setting and did not see anything wrong. Please download video.
https://www.dropbox.com/s/afxv1i1vm69goeu/IMG_6290.MOV?dl=0
My question is, even if the wall thickness is not a multiple of the line width, why would the Z axis jump? Is it a bug?
thank you so much.
MKZ
gr5 2,332
ALWAYS look at the print in layer view before printing the part.
I'm guessing the wall got too thin for a bit. You can either make "line width" smaller (and make wall thickness a multiple of wall line width).
Or alternatively try checking "print thin walls".
And ALWAYS look at the print in layer view before saving/printing. You would have noticed the problem without starting the print.
