Posted
· Cura Interaction with Autodesk Fusion 360
Thanks @ghostkeeper I'm a bit confused though about where the system command is. When I use Cura 15.04 as the 3DP Utility it opens a single instance, but when I use 3.2.1 it doesn't.
As I write this though I have maybe realised the difference. When I use Cura 15.04, that's already available as pre-installed option in the default dropdown list, whereas I have to link Cura 3.2.1 as a "Custom" 3DP Utility. There must be a different system command being used when it's installed from the pre-installed link compared to the custom generated link.
My apologies - it doesn't sound like Cura is the issue here. Once I understand it better I may need to post this request to the Fusion 360 IdeaStation instead.
1
SteveCox3D 80
