I'm in the normal view mode and the fix horribles are unchecked.
I'm fine with autoslicing/prepare but ONLY if doesn't impact other operations (bugs excluded), otherwise it's a design choice that can NOT be justified. Actually that should be the reason for it to be in the background, not its speed.
gr5 1,856
Are you in the normal view mode? I can rotate in normal view mode INSTANTLY after changing a parameter even if it takes a full minute to slice. I can rotate before the progress bar comes up. I can rotate after the progress bar comes up.
So something is wrong. Unless you are in slice view in which case I have the same issues.
Several people reported these bugs somewhere but I forget where (probably above in this very thread) and there were either bug fixes or workarounds for all of them. I thought the latest Mac version (which is newer than the latest PC version I think) fixed one of the problems that was Mac only related.
Also: do you have any of the 4 "fix horrible" boxes checked? These perform cpu intensive work before the slicing starts.
Unfortunately, Daid is much slower at fixing "mac only" related issues as he probably doesn't have the issue you are having on the few Macs he *does* have access to.
Daid's philosophy is not to add a workaround (turning off slicer) to fix a bug that needs fixing. The bug itself should be fixed, otherwise if he gives people the slicer-off feature people won't complain and the bug will never be fixed.
