The bed uses the most amount of power and the nozzle uses the second most. What is happening is when both heaters are on and then the servos start you trip something in the power brick. The probably is 99% most likely in the power brick. Did you change the heater in the print head recently? If not I think you should just get a new power brick.
Quote
Meanwell power supplies.
GST220A24-R7B
GS220A24-R7B
Try to get the "GS" and not the "GST" version if you can. The GST is more efficient but the GST also is much more likely to shut off unexpectedly - in other words the GS has a larger headroom and can put out more power. Both put out more power than labelled but the GS puts out more and the UM2 series printers basically need the extra power.
We don't often release an alpha version of Ultimaker Cura... So what's different this time? This Alpha contains such a huge slicing engine overhaul that we really need your help!
We wish to celebrate and honor the innovators that push forward the field, technology and world. We opted to not present it as a competition or ranked list. Every innovator has earned his spot on that list in their own way. We also look at the 3D printing industry as a whole and not limit the list to those only using Ultimaker.
gr5 1,504
