Cura 3.x has no way to specify the port, it only has automatic discovery. That’s the same on all OSes.
Edited by ahoebenAs far as I remember the user (= you) that runs a software which should communicate with usb-ports must belong to the group "dialout" to use the ports.
Give it a try, just open a terminal an type in
sudo adduser xxx dialout
where "xxx" is your username.
2
- 1 month later...
On 11/3/2018 at 6:52 PM, berndjm said:As far as I remember the user (= you) that runs a software which should communicate with usb-ports must belong to the group "dialout" to use the ports.
A little late, but I can confirm that
"sudo usermod -a -G dialout [your_username]"
did the trick for me. Actually I neater found nor did the trick, it came to me by "accident" as I installed Arduino IDE (for playing with Marlin FW), and it did it all for me.. It was never Cura, just a stupid permission, however there is a way for software to ensure the needed permissions to work, so here we are..
(BTW RepetierHost and Repsnapper now works for me as well)
- 11 months later...
Adding the user to group dialout is a necessary 1st step.
After changing the baudrate of the (virtual) serial port from 250000 to 115000 in Marlin Configuration.h and uploading the new firmware, Cura on Linux connected to the printer without any problem.
gr5 2,098
I use cura from ubuntu.
Try ~/.config/cura
But I don't see anything in there about "com" or "usb" or "port".
