Out of interest, what's the problem with more than 2 columns?
kmanstudios 1,120
1 hour ago, ahoeben said:Out of interest, what's the problem with more than 2 columns?
It is hard to count that high
On 3/17/2018 at 12:04 PM, yellowshark said:Hi @SandervG this is a really good idea from @brianskyze ; I have to write down notes for every print I do (and even then there are certain lesser settings do not get noted) - hitting a print key would be so much easier
I agree! Little tip; when you tag a person you have to select the username from the dropdown list following @.. this is necessary to make a link to the database with user-accounts and you are not just writing something with an @. It would be the difference between @yellowshark and @yellowshark.
Perhaps it could be a nice plugin. I assume it is something one would select through file > export or something, and it doesn't generate a .csv automatically?
yellowshark 153
I confess to only quickly skimming recent posts but I do wonder if we are trying to disappear up our own tail. Cura must already have all the code and data it needs because it displays the data we want on to the computer monitor. All (lol) it has to do is to route that "display" somewhere else, be that a document or a database record(s)
yellowshark 153
1 hour ago, SandervG said:Ah I was not aware that the new forum had changed this. I thought that the selection box was there to help if necessary but one could still type the tag into the message directly.No wonder no one responds to my tags
13 hours ago, ahoeben said:Out of interest, what's the problem with more than 2 columns?
In itself there is no problem with more columns. The problem would be if the data is divided over multiple columns, for example:
Column A [TAB] Column B [TAB] Column C
Nozzle temp: [TAB] °C [TAB] 210
Number of skirt lines: [TAB] 3
Here the temp is sitting in column C, while the number of skirt lines is in column B. Then you can not simply copy and paste the whole column with data into an Excel worksheet, into a prepared template. It would require manually re-arranging some data into different columns. For printing as a plain text file, it does not matter of course.
The idea is similar to when copying data from a TXT-file into an Excel worksheet, to produce a graph. You want all the X-axis data in one column, and all Y-axis data in another column. If this would be a material test that is repeated 100 times, then we can simply copy the column with X-values into a prepared worksheet, and copy the Y-values, and immediately have a nice graph.
It wouldn't matter if you would use two columns, like this:
Description (units) | Numerical data
Or three columns:
Description | Units | Numerical data
Or whatever else, as long as all items use the same layout, and all numerical data end up in the same column. That was the idea.
- 2 years later...
Has anyone ever made a feature request about this here:
https://github.com/Ultimaker/Cura/issues ?
I have imported some materials from marketplace which are lacking profiles (only Fast and Fine are existing). For technical stuff I love Engineering Intent Profiles. But I can't simply copy them as custom profiles because they are relying on other profiles that won't exist for the imported materials.
A good explanation about deriving settings from the different profile layers is here (thanks to nallath):
https://github.com/Ultimaker/Cura/wiki/Profiles-&-Settings
It would be great to have a way to export the settings to a text file. That way it would be much easier to build a similar profiles for different materials. It would be even better if there were an information given in the exported file from where the setting is originated (user/material/quality profile/intent profile/machine). Although that might be more difficult because there are also settings calculated by a formula.
You can find some plugins on github to export your profile under an HTML Document (in this case only values are exported. It's a full description without formula so every setting is easy to figure out)
https://github.com/johnnygizmo/CuraSettingsWriter
A curapackage for Cura 4.6 for this plugin can be found there :
You just have to drag and drop this file into Cura (4.6.1) for a direct installation.
It creates an extra menu option under File -> "Save Project..." that allows you to save all of the settings to an HTML file for review/sharing.
Edited by Cuq
That's great.
I can easily pull it from the HTML to do kind of automated comparision.
On 6/8/2020 at 11:50 AM, Cuq said:You can find some plugins on github to export your profile under an HTML Document (in this case only values are exported. It's a full description without formula so every setting is easy to figure out)
My joy was a bit premature. When looking at the values from the HTML output of the plugin some of the settings would differ from the values given in the Cura GUI.
I have hesitate for some days to look into the code of the plugin as I have never coded Python nor have I found many informations about the internal objects structure of Cura. Cause i'd really like to have a readable export of settings I have now tried.
It seems that in the plugin all settings values are pulled from global stack
machine_manager = application.getMachineManager()
global_stack = machine_manager.activeMachine
But for a dual extruder machine where settings can be different for extruder 1 + 2 for some settings a single value can't be all.
I found this information here:
https://community.ultimaker.com/topic/22507-how-can-i-get-settings-in-postprocessing-plugin-script/
"Cura has multiple "stacks" containing settings; a global stack that has all the settings that are properties of the printer (such as machine_start_gcode, build plate dimensions, but also those settings in the sidebar that have a "link" icon), and one or more extruder stacks for settings that can be different for each extruder. "
So I tried to simply use the extruder stack instead of the global stack in the plugin code but I got less settings in the machine category (somehow understandable and the category isn't visible in the settings pane of the GUI anyways) but also none of the settings in the material category. So a really important part (temperatures) where missing.
I have now tried to get the setting names from the global stack and request the corresponding values from the extruder stack.
Can anybody confirm that this is a valid approach?
For the machine category sounds logical as they are global settings, but the temperatures should be linked to the extrudeur. Anyway that's clear this code must be improved for a dual exturder. But it should be not so difficult on my point of view.
Edited by CuqBased on the wiki explanation about profiles and settings here:
i have just made minor changes to the code (marked with ->). At the moment just enough to test on one extruder stack.
Copyright (c) 2020 5axes # Initiale Source from Johnny Matthews # The SnapShot plugin is released under the terms of the AGPLv3 or higher. from UM.Application import Application from cura.CuraVersion import CuraVersion # type: ignore from UM.Preferences import Preferences from UM.Settings.ContainerRegistry import ContainerRegistry from UM.Workspace.WorkspaceWriter import WorkspaceWriter -> from cura.Settings.ExtruderManager import ExtruderManager import UM.Settings.SettingRelation class CuraSettingsWriter(WorkspaceWriter): def write(self, stream, nodes, mode): stream.write("<style>") stream.write(" .category { font-size:1.5em; } ") stream.write(" .off { background-color:grey; } ") stream.write(" .valueCol { width:200px;text-align:right }") stream.write("</style>") application = Application.getInstance() machine_manager = application.getMachineManager() stack = application.getGlobalContainerStack() -> extruder_stacks = ExtruderManager.getInstance().getActiveExtruderStacks() global_stack = machine_manager.activeMachine #jquery = open("plugins/plugins/CuraSettingsWriter/jquery-3.3.1.min.js","r", encoding="utf-8") stream.write("<script src='https://code.jquery.com/jquery-3.3.1.slim.min.js'></script>\n") stream.write("""<script> $(document).ready(function(){ $("#enabled").on("click",toggleDisabled); }); function toggleDisabled(){ $("tr.disabled").toggle(); } </script> <h1>Cura Settings Export</h1> <button id='enabled'>Toggle Disabled</button><P>""") stream.write("<table width=50% border=1 cellpadding=3>") # Version stream.write("<tr>") stream.write("<td class='ok' style='width:50%;padding-left:25'>Cura Version</td>") stream.write("<td class='ok' colspan=2>" + str(CuraVersion) + "</td>") stream.write("</tr>\n") # Job J_Name = Application.getInstance().getPrintInformation().jobName stream.write("<tr>") stream.write("<td class='ok' style='width:50%;padding-left:25'>Job Name</td>") stream.write("<td class='ok' colspan=2>" + str(J_Name) + "</td>") stream.write("</tr>\n") # Snapshot #stream.write("<tr>") #stream.write("<td class='ok' colspan=3>" + str(F_Name) + "</td>") #stream.write("</tr>\n") # Profile P_Name = global_stack.qualityChanges.getMetaData().get("name", "") stream.write("<tr>") stream.write("<td class='ok' style='width:50%;padding-left:25'>Profile</td>") stream.write("<td class='ok' colspan=2>" + str(P_Name) + "</td>") stream.write("</tr>\n") # Quality Q_Name = global_stack.quality.getMetaData().get("name", "") stream.write("<tr>") stream.write("<td class='ok' style='width:50%;padding-left:25'>Quality</td>") stream.write("<td class='ok' colspan=2>" + str(Q_Name) + "</td>") stream.write("</tr>\n") # Material # M_Name = extruder.material.getMetaData().get("material", "") extruders = list(global_stack.extruders.values()) M_Name = extruders[0].material.getMetaData().get("material", "") stream.write("<tr>") stream.write("<td class='ok' style='width:50%;padding-left:25'>Material</td>") stream.write("<td class='ok' colspan=2>" + str(M_Name) + "</td>") stream.write("</tr>\n") # Define every section to get the same order as in the Cura Interface -> self._doTree(global_stack,extruder_stacks[0],"resolution",stream,0) -> self._doTree(global_stack,extruder_stacks[0],"shell",stream,0) -> self._doTree(global_stack,extruder_stacks[0],"infill",stream,0) -> self._doTree(global_stack,extruder_stacks[0],"material",stream,0) -> self._doTree(global_stack,extruder_stacks[0],"speed",stream,0) -> self._doTree(global_stack,extruder_stacks[0],"travel",stream,0) # If single extruder doesn't export the data extruder_count=stack.getProperty("machine_extruder_count", "value") if extruder_count>1 : -> self._doTree(global_stack,extruder_stacks[0],"dual",stream,0) -> self._doTree(global_stack,extruder_stacks[0],"cooling",stream,0) -> self._doTree(global_stack,extruder_stacks[0],"support",stream,0) -> self._doTree(global_stack,extruder_stacks[0],"platform_adhesion",stream,0) -> self._doTree(global_stack,extruder_stacks[0],"meshfix",stream,0) -> self._doTree(global_stack,extruder_stacks[0],"blackmagic",stream,0) -> self._doTree(global_stack,extruder_stacks[0],"experimental",stream,0) -> self._doTree(global_stack,extruder_stacks[0],"machine_settings",stream,0) # This Method is smarter but unfortunatly settings are not in the same ordrer as the Cura interface # for key in global_stack.getAllKeys(): # if global_stack.getProperty(key,"enabled") == True: # if global_stack.getProperty(key,"type") == "category": # self._doTree(global_stack,key,stream,0) stream.write("</table>") return True -> def _doTree(self,stack,extruder_stack,key,stream,depth): #output node if stack.getProperty(key,"type") == "category": stream.write("<tr>") stream.write("<td class=category colspan=3>" + str(stack.getProperty(key,"label")) + "</td>") #stream.write("<td class=category>" + str(key) + "</td>") stream.write("</tr>\n") else: style = "ok" if stack.getProperty(key,"enabled") == False: style = "off" stream.write("<tr class=disabled>") else: stream.write("<tr>") -> stream.write("<td class="+style+" style='width:50%;padding-left:"+str(depth*25)+"'>" + str(extruder_stack.getProperty(key,"label")) + "</td>") -> GetType=extruder_stack.getProperty(key,"type") -> GetVal=extruder_stack.getProperty(key,"value") if str(GetType)=='float': GelValStr="{:.2f}".format(GetVal).replace(".00", "") # Formatage else: GelValStr=str(GetVal) stream.write("<td class='"+style+" valueCol'>" + GelValStr + "</td>") -> stream.write("<td class="+style+" >" + str(extruder_stack.getProperty(key,"unit")) + "</td>") stream.write("</tr>\n") #look for children if len(stack.getSettingDefinition(key).children) > 0: for i in stack.getSettingDefinition(key).children: self._doTree(stack,extruder_stack,i.key,stream,depth+1)
The comment in the original code is correct, you can't use getAllKeys() on a stack if you wan't to have the same sequence that you see in the GUI. The original idea of getting the categories (Infill, Speed etc.) and pulling the children recursively seems to work. But I have made a lot of assumptions:
1. The extruder stack (or all stacks) won't list settings as children if there is no direct value for them in the stack. That would explain why I don't get some settings if I simply replace the global stack by the extruder stack. So I kept the code to and get the complete settings from the global stack.
2. According to the above mentioned doc about profiles and settings:
"The extruder stack will then ask each of the profiles that it has (in sequence) if they have a value for the requested setting"
I take every setting from the global stack and ask the extruder stack for the value and hope the result is the same as given in the GUI
3. The next part of the wiki doc about formulas to calculate values for settings:
"When we ask for the value of "foo", we expect to get 25 as a result. The following calls will be made in order: ..."
Could be a bit more clear - who makes the calls in order?. I hope that the extruder stack will do it for me and will deliver the correct value so I don't have to do the calls in the plugin code.
With all these assumptions I am not really sure about my results.
- 1
In my case I will use the Settings of the extruders[0] for platform_adhesion, support, meshfix ,blackmagic ,experimental and Machine and the individual extruders for the other settings
Have a look to my modified solution :https://github.com/5axes/CuraSettingsWriter/blob/master/HtmlCuraSettings.py
Edited by Cuq
- 1
last curapackage : https://github.com/5axes/CuraSettingsWriter/blob/master/Package/HTMLCuraSettings-v7.0.0-2020-06-12T16_31_19Z.curapackage
Download it and drag& drop in the Cura windows for installation ( 4.6)
22 hours ago, Cuq said:
Thanks for completing the changes and building the package.
If you like to maintain it, I think it is better to format numerical values like this:
GelValStr="{:.5f}".format(GetVal).rstrip("0").rstrip(".")
else:
it is better mimicking the GUI. The original code will give rounded values with 2 decimal places even when the GUI shows more decimals.
For myself I have changed the plugin to make an CSV file because my main purpose is to compare different profiles and I can feed that directly into Excel to show the differences.
- 2
Good suggestion but i will use :
GelValStr="{:.4f}".format(GetVal).rstrip("0").rstrip(".")
5 is too much for me. And I don't really see the benefits of a CSV format if it's just to open in Excel . An HTML file is much more easy to open directly in Excel compare to an CSV file (Just my point of view)
Edited by CuqIt's just easier to make an automated comparision from pure lists:
I am quite happy with it.
BTW: In my code I have kept the pulling of the settings from the extruder stack. It seems the stack is requesting the values from the right place. The benefit is that for the Machine settings it gives the correct Nozzle ID and Diameter for both extruders.
Maybe it's possible to get this values in the same way as the material from the global stack extruders values:
# Material
M_Name = extruders[extruder_stack.getProperty("extruder_nr","value")].material.getMetaData().get("material", "")
But I don't know how to do that.
Edited by r_moeller
- 1
- 4 months later...
Dear colleagues,
thank you for this great job. Has anyone tried to use the plugin in version 4.7.1? I'm afraid of crashing my installation by testing it.
Did you instal it via the market place ?
- 8 months later...
For anyone reading this, there is now a plugin available inside the Cura marketplace, that allows the export of profile settings to .csv (text). Also one that exports to HTML if you fancy it!
- 1 year later...
geert_2 557
Addition:
For easy importing in Excel, for example if you want lots of profiles in one big table, for a good overview and easy comparing, it is desirable to have only two columns (A and B) in the text-output. And the units being part of column A. Like this:
Profile name: [TAB] Normal PLA
User comment: [TAB] This is my usual PLA profile
Printing speed (mm/s): [TAB] 50
Traveling speed (mm/s): [TAB] 150
Nozzle temp (°C): [TAB] 210
Number of skirt lines (#): [TAB] 3
In which [TAB] is of course a tab-stop. A semicolon would also do (or better, user-selectable). But no comma's, since they might interfere with European decimal points.
In this way we can open such a file in Excel, and directly copy column B into a template with a big table. Or we can easily print it from Notepad, or from Word.
