ghostkeeper 105
It depends a lot on what you need.
If you need to transform the g-code into something that's better understood by your printer, then a post-processing script could do the job. But if you need to do something different depending on, for instance, whether you're printing overhang or not (to maybe tilt the platform a bit to get better overhang), then you're almost certainly stuck with modifying CuraEngine itself, or you'll have to try and reconstruct from the g-code which areas are overhang.
But if you're actually going to try to print curved layers and such to print something from inside out, well, I don't think that Cura will be of much use at all.
Edited by ghostkeeper
gr5 2,095
Wow. That's not built into cura but you could write a plugin to do that. You would apply a transform to all the G1 and G0 commands depending how much you have rotated or tilted the base. The easiest kind of plugin isn't called a plugin - it's called a post processing something. I think there are samples you can look at. If you can't find one I can send you a sample.
