Thanks !!!! I have the withe feeder and yes i installed the UM2 + firmware , today i reinstalled the firmware , rebooted the printer and it worked....... very strange!
I forgot to mention you want to do a FACTORY RESET on the menu. Some of those things (like steps/mm for the E axis) are stored in the eeprom area and different versions of the firmware (marlin) store it in different places so it's best to do a FACTORY RESET after installing firmware unless it was definitely 100% an increase in version from one UM official release to another official release.
For example if you switch to tinkerMarlin or from tinkerMarlin you definitely want to do a FACTORY RESET.
gr5 2,005
The UM2 and the UM2+ have reverse direction feeders. You got the wrong software. If you have a white feeder on your UM2 then use the "plus" firmware. If you have a black feeder on your UM2 then don't use the "plus" firmware. Just regular UM2 extended.
