now also note that the material used in the ";MATERIAL:" tag is in cubic mm and not in meters.
So that makes sense to me, the UM2 sees no material used in the metadata of that file.
What is worse, your gcode is not compatible with an UM2!
You set your gcode flavor to reprap in Cura and this results in gcode where the E steps are in mm of material use and not in the cubic mm of material used by the UM2(+). So this is not only a cosmetic change of the metadata.
Edited by robinmdh
robinmdh 93
If this is on a UM2(+) then please note that this is not the format used by ultigcode (this is the format used for the UM2).
example of ultigcode:
this is what your file has:
Edited by robinmdhLink to post
