Problem Adding Post Processing Modify G-Code script
Peter J Tyers
Posted · Problem Adding Post Processing Modify G-Code script
This may duplicate material already discussed - could not fing anything under "add extension script"
Attempting to add a post processing extension script under modify G-Code
configuration Windows 10 X64
Cura 3.2.1
Monoprice Mini V2
added .py script from https://www.thingiverse.com/thing:1298948   VaryTempWithHeightCura3.py
to allow variation of extruder temperature with heght.
Placed it in C:\Program Files\Ultimaker Cura 3.0\plugins\PostProcessingPlugin\scripts\
Started Cura against an .stl file.
when model shown clicked Extensions-Post Processing-Modify G-Code
Got Post Processing Scripts Window
clicked Add Script
My new script is not displayed in list
What am I doing wrong?
    Well, if you are running Cura 3.2.1, I would say that you should use C:\Program Files\Ultimaker Cura 3.2 instead of \Ultimaker Cura 3.0.
    But the better place to put the script is in the configuration folder. In Cura go to Help -> Show configuration folder. In the folder that opens, there will be a folder named "scripts". Put your script in there.
    in addition:  read the comments on thingiverse...
    Quote
    The script won't load and throws an error because the file name differs from the class name contained in the file. Rename the file to:
    VaryTempWithHeight.py
    The file "cura.log" in the configuration folder should contain appropriate error messages (or warning), if a script can not be loaded.
