I used PLA for my pulls, though as i mentioned I have replaced the nozzle since to a new one. How do I check the coupler exactly?
kmanstudios 1,117
You need to do atomic pulls with the higher temp material, or, an even higher temp material. PLA is not a good thing to do a cold pull with PETG. Go back with PETG or a higher temp material to really clean it out properly. It is not just the nozzle, but maybe some stuff backed up a bit higher in the core.
1 minute ago, kmanstudios said:You need to do atomic pulls with the higher temp material,
Thats some good advice. Nylon works quite well and there are also some cleaning filaments on the market.
2 minutes ago, kmanstudios said:It is not just the nozzle, but maybe some stuff backed up a bit higher in the core.
Ultimaker 2 machines don't use print cores.
Next up after the nozzle is the coupler. Upper left is a new coupler and bottom right a worn out coupler, which can lead to underextrusion.
Picture: Ultimaker.com
Have a look at this guide to check your coupler: https://ultimaker.com/en/resources/22188-how-to-replace-the-tfm-coupler
3 minutes ago, Plushberry said:The coupler seems to be fine, still fairly white in color.
You need to disassemble the print head to check the bottom side of the coupler. The top doesn't wear out.
1 minute ago, cjs said:You need to disassemble the print head to check the bottom side of the coupler. The top doesn't wear out.
Will do after the pulls. Thanks for the help
theres are the results from my pulls from left to right being first to last. For some reason the second time the fillament seemed to have broken inside thoug I coudnt see any bits of fillament in the coupler. the third pull I pulled while the temp was at about 105 which is why it came out elongated.
kmanstudios 1,117
5 hours ago, cjs said:Ultimaker 2 machines don't use print cores.
Ya gots me. I was calling it core for a lack of a better vocabulary. I was referring to the area just before the nozzle. Now, looking at the pics, it would seem that would be the coupler, yes? Always out to learn something even if I do not have the machine. I have seen a lot about couplers, but this is the first time I have seen the pics.
it seems it was indeed the coupler. I have been printing the architectural model parts and they seem to be coming out fairly well
cjs 33
What material did you use for the atomic pull?
You may also want to check the coupler as this is a common problem on Ultimaker machines. Printing PETG at higher temperatures also leads to higher wear of this item.
