Thanks for the answer. After adding the script, what do I do then? How do I use it? Does it appear in the Plug-ins option?
Sorry to seem a little pedantic but a bit more explanation would help......
Will try adding it later and see if I can work it out myself......
Kindest Regards, Dan.
ahoeben 1,657
See the menu Extensions -> Post Processing -> Modify Gcode. Add the script "Pause at height".
