nomadic318 0 Posted March 21 in Weird spiral pattern on print I designed this in openscad, and transfered it to cura. I've done this with several other other designs and never had a problem. It should be smooth not have this weird spiral pattern on it. I don't know what's happening. Share this post Link to post Share on other sites
jofleck 0 Posted March 21 in Weird spiral pattern on print Is it possible that you accidentally switched on the vase mode? Share this post Link to post Share on other sites
kmanstudios 505 Posted March 21 in Weird spiral pattern on print Vasemode woould have left only a single shell. That seems to have thickness. It is weird. It would help to know printer, filament, settings etc. otherwise it was the work of the printergeists at work. Share this post Link to post Share on other sites
mastory 31 Posted March 21 in Weird spiral pattern on print I think maybe not enough cooling. Fan is working? Have the other successful prints had a larger X-Y area, thereby allowing more cooling prior to subsequent layers? Maybe try a combination of slower print time, increasing minimum layer time, and maybe enable Lift Head? I sometimes print 2 or more small area parts to provide more cooling time and pick the best one when its done. Share this post Link to post Share on other sites
cjs 23 Posted March 21 in Weird spiral pattern on print 1 hour ago, nomadic318 said: To me this looks like some feeder/extruder issues. I would do some atomic/cold pulls. Check the consistency of your filament. Manually push the filament into the hotend to see if the temperature is right. Share this post Link to post Share on other sites
nomadic318 0 Posted March 22 in Weird spiral pattern on print Where would I find vase mode? Here are my printer settings. I'm not sure what filament I'm using, I got it a while ago, but I haven't had any issues in the past with it. Also i am using an anet a8. Share this post Link to post Share on other sites
kmanstudios 505 Posted March 22 in Weird spiral pattern on print 1 hour ago, nomadic318 said: I'm not sure what filament I'm using ummmm, same filament that was successful so far? The reason I am asking is if you went from a low temp filament to a high temp filament, that would create massive underextrusion. The version you show is a previous version that is before my time. Sorry, but there are those who are familiar with it. Share this post Link to post Share on other sites
nomadic318 0 Posted March 22 in Weird spiral pattern on print Yes, when i bought the printer a year or two ago I bought a few spools of the same fillament. Thats all I've ever used. Share this post Link to post Share on other sites
kmanstudios 505 Posted March 22 in Weird spiral pattern on print 6 minutes ago, nomadic318 said: Yes, when i bought the printer a year or two ago I bought a few spools of the same fillament. Thats all I've ever used. Just ruling out things....have you tried the hot and cold pulls and see if there is a clog? Share this post Link to post Share on other sites
gr5 897 Posted March 22 in Weird spiral pattern on print Please show the other settings as well. And can you zoom in on the part more? It looks maybe underextruded but I can't tell. and check your part in layer view - does it look fine there? I can't tell from the photo but the only thing that makes sense to me is underextrusion. Also when you post your settings, tell us what your nozzle diameter is. Share this post Link to post Share on other sites
