Do you have a multimeter? Disconnect this cable at the *other* end underneath the printer and measure the resistance there. It should be around 100 ohms. If it's failing it should be well over 1000 ohms. While one person holds the multimeter to the two wires, another person needs to push and poke at these connections. Push quite hard - maybe 1kg force. Hopefully, the resistance will jump from around 100 ohms to infinite. when that happens you found the problem area.
Alternatively, turn the printer on and go to SYSTEM and go to where you set the bed temperature and leave the temperature at 0C but have one person watch the temperature while the other person pokes at these connections. The problem with this approach is that every time the temperature goes over 700C you will then probably have to reboot your printer and start over until you find the problem spot.
I have error showing.
ERROR sensor BED
The problem is its is intermittent .
I have re-solder connecting block on bed.
Checked board connection .
Tested for O/S wires from board to bed.
I getting a reading of 109ohms resistor? on bed.
I can get one print (first of the day) , try to print again some times OK some times fault.
The printer has done several hundred hours
Is it the board or bed?
Ultimaker 2+
I upgraded to + months ago
thanks gromit
- 9 months later...
Hello,
Just want to add to this, as I am experiencing the same symptoms as gromit on an Ultimaker 2+ Extended, the one with the connection style shown in Megatarts image.
Similarly I can do one print each day, then the error persists for some time afterwards.
I soldered jumper wires directly from the connectors to the PT100, and still the error persists.
How likely would it be that the PT100 itself has failed somehow, or the sensor wires from the bed? They do seem to be bending nicely without obvious kinks or strain.
As an additional note, I've only ever seen the error thrown when the bed has fully descended to it's lowest position, not during a print.
Cheers,
Travers.
I soldered wire directly to printing bed, Over 100 prints after fix all working well.
gromit
- 3 years later...
Sorry for replying to an old topic, but this is the same problem I have.
I ordered a new bed and new cable, does it matter if I swap the thick cables? Same question for the sensor cable. So I mean, can I swap the plus and minus simply? Probably not, but I cant see which of the thick cable goed where, to 24V or the 7.5 A
Hi @kupfeli,
The heat bed is a floating heater element, so no need to select polarity here. Also, the text mean input 24 V with current (needed minimum) 7.5 Amp.
The PT100 (platinum sensor) is also a floating "resistor", -so neither this connection is polarity required.
As you ordered all stuff for the bed, why not just change all?
In the past, there was "some" problem with the connection of the high power wires to the bed. There was a few problem with the bed sensor PT100, that's not much of a problem anymore.
But for folks using this "exotic" high temperature filament, things really put those components to the the edge and may expect some more error as shorter life span for those items is sure to be seen.
Hope this help.
Thanks
Torgeir
1
1 hour ago, Torgeir said:Hi @kupfeli,
Hope this help.
Thanks
Torgeir
Hi Torgeir,
Thank you very much for your terrific answer!! I will now swap out the heatbed and the cable and will then go and try to print something.
Will edit my post when I have result that can also benefit others.
Thanks again very much!!
EDIT: Yes, my problem is solved on my Ultimaker 2+ Connect!!!
The bed is getting hotter than ever (not too hot, but 60 degrees is already quite hot), I havent had the bed this hot before and the cooling down works again, it does not hang anymore and no ER203 error anymore (I had that error sometimes).
Probably the bed was already not functioning correctly a while ago.
Edited by kupfeli-
1
gr5 1,870
more info here: http://ultimaker.com/ER02
This is almost certainly a problem at the bed and not the board. When things heat up they expand. A contact along the temperature sensor path is a bad connection and when things heat up and expand it loses connection. Slowly. As it loses connection the resistance suddenly rapidly increases and that looks to the logic just like increased temperature. But it's not increased temperature - it's a slow motion disconnection.
The problem is most likely right where the connector is. Also it could be a trace on the board or it could be the sensor.
I'm an engineer - if you or someone you know is good with a multimeter you can fix it yourself pretty easily. This is like a 20 minute fix for me.
I would take it all apart so you can get access to the tiny little PT100 chip (it's the only chip on the board - you can follow the traces visually that the smaller two wires go to over to that chip.
I would first just reflow the solder at the PT100 chip and at the connector. It's almost certainly the connector. There is mechanical stress there when the board moves and several people have had problems on the forum with that connector not soldered well enough. At least on the UM2. Basically the UM3 is identical in this regard and I don't remember if anyone has had a problem with the UM3 connector but if they get what you describe it's probably the same spot - the connector.
99% chance this fixes it. If not I would connect it back up and just hanging (not screwed in) and connect the larger two cables to a 24V 200Watt supply (not easy to find) and heat it up to 100C and while that is happening measure the resistance of the PT100. It will slowly increase from 109 ohms at room temp to around 200 ohms when hot but then suddenly sky rocket to infinite ohms. At that point you can probe each point along the path and find out where the failure is exactly. It might be that you need to run two tiny wires from the connector over to the pt100. In fact I'd just run those 2 wires if the reflow trick doesn't work and not even bother heating it.
OR you can get a new bed heater from your reseller.
Megatarts 0
Thank you for such a comprehensive answer!
I read this wrong the first time and took apart the main board, looking for the PT100 chip. The good news is that all none of the joints there look dry.
After reassembling all that, I took a look at the proper location, and ran into what I imagine is a really stupid problem -- I honestly don't know how to disassemble it to a point where I can reflow the solder. Here's a photo of what I'm looking at -- pulling on the wires doesn't seem to remove them.
