kmanstudios 1,099
1 hour ago, ahoeben said:
Though that makes things easier to implement, the main reason why I am hesitant to do that is that the support blocker acts on the surface of the model. It would be confusing to have two tools, where one would act on the buildplate and one would act on the model. Marking areas on the buildplate alone does not cover cases where you need support that does not "touch the buildplate".
I think this is where having that little 'ahoeben continent' of features explained or demonstrated would be helpful. It may answer the question others have as well as myself.
And, why a continent? Because 'No man (or woman) is an island!'
1
Top Posters In This Topic
23
19
13
10
Popular Days
Mar 27
23
Apr 11
15
Mar 28
15
Mar 29
15
kmanstudios 23 posts
ahoeben 19 posts
SandervG 13 posts
rebekah_harper 10 posts
Popular Days
Mar 27 2018
Apr 11 2018
Mar 28 2018
Mar 29 2018
Popular Posts
SandervG
After another period of continuous research and development, we're proud to share the latest Ultimaker Cura Beta with you. We're excited to hear what you think of the new and improved features. With y
ahoeben
Drawing a polyline on a mesh inside Cura to create new geometry would be quite computationally expensive (to the point of not being feasible for now). The “christmass may come early” plugi
burtoogle
Thanks for the mention @SandervG, I will put together a topic that describes the new bridging features and the associated settings.
Posted Images
ahoeben 1,186
ahoeben 1,186
The Cura logs (cura.log) are found in the "Configuration Folder". Normally, when Cura is not crashing, you can access the configuration folder through the Help menu (Help -> Show configuration folder). Since Cura crashes on startup for you, you will have to locate the folder directly:
%APPDATA%\cura\<Cura version>\cura.log
which is usuallyC:\Users\<your username>\AppData\Roaming\cura\<Cura version>\cura.log
~/Library/Application Support/cura/<Cura version>/cura.log
~/.local/share/cura/<Cura version>/cura.log
