I'll post a picture of the settings and the code tonight. I do know, however, that I set the resume temperature setting. The one time I forgot to do so, the system never moved again waiting for a 0 temperature. Right now the printer goes back and keeps moving but it does not extrude the filament.
Well I figured out my problem. Since I updated to 3.2 and now 3.2.1, the g-code is set to M83 (relative extrusion mode). This was not a selection I made anywhere as far as I know. Well, the Pause at Height script ends with an M82 (absolute extrusion mode). I changed this to M83 and now it works.
My only question now is, is the extrusion mode something I can choose on Cura?
tinkergnome 929
Hi ElClipo,
can you show a screenshot of your settings for the post processing script?
The symptom sounds like you forgot to define a "Resume Temperature"...
