Posted (edited) · Cura won't print a small object
I am trying to print a 200mm long rectangle that has been shelled out. The end is 24.5 by 2.75 with a wall thickness of 1mm.  When i scale up 280% in cura it will show something to print.  Are there some limits to wall thicknesses that cura can slice? I tried changing shell thickness to no avail.
Edit figured out that I was exporting from Autodesk Inventor in cm when I should've been in mm.
Edited by GFlow
Solved
