Printer and material profiles lost 3.2.1
Duncan_B
Posted · Printer and material profiles lost 3.2.1
13 hours ago, Msuurmond said:
We can only help you further if you can give us the complete config folder. With that we can extract it on our development machines and create the exact same situation as you have. If anything goes wrong we can than see it and fix it.
How do I do that when zip files are not allowed to be posted.  I would gladly send you anything you want but don't know how
Dr. Dave
    Dr. Dave
    A few options:
    - You could use https://wetransfer.com/ to upload the zip to and share the link here so we can download it.
    - Rename the zip-file so it doesn't end on .zip but on .3mf for example
    9 hours ago, Msuurmond said:
    A few options:
    Sheesh that was freaking BRILLIANT
    I should have thought of that
    Here is the 3mf that is REALLY a ZIP file after you change it back
    Thank you SO much
    Dr D
    3.3.3mf
    Thank you SO much
    Dr D
    3.3.3mf
    Ok I got the files, but I only see a 'cache' folder in the zip-file. We need the whole 3.2 folder e.g.:
    On 4/26/2018 at 6:27 PM, pgrunwald said:
    I'll try it tonight when I get home from work.
    I'm still at 3.2.1,  Do you want me to just try a normal upgrade?
    Hey @pgrunwald, yes. But first make sure to delete the 3.3 configuration folder before you launch the 3.3.1.
    Let me know how it goes! :)
    Thank you SO much
    Dr D
    3.3.3mf
    Hey @drdave!
    I also got the file, and same as @Msuurmond, I see only the cache and it looks like it's 3.3.
    Can you please check the \Application Support\Cura  again and look for the whole 3.2 folder? That's what we need to check. :)
    Thanks
    37 minutes ago, ElleCross said:
    Hey @drdave!
    Thanks
    SO SORRY I thought you wanted the 3.3 here is 3.2 change to zip
    Sorry I misunderstood I thought you wanted the new folder created not the old one
    Dr Dave
    3.2.3mf
    Dr Dave
    3.2.3mf
    Got the file, but this is still only the cache folder. We need this folder:
    $USER/AppData/Roaming/cura/3.2/
    I am right clicking the folder as you asked then clicking add to zip then renaming it and sending it NOT sure what else I can do
    I also can't be the ONLY one with this issue so how about someone else stepping up here and getting the team what they need
    When I first posted this there were several others who had the exact issue
    Here is the file labeled stl return to zip and let me know, please
    THANK YOU ALL
    Dr. D
    3.2.stl
    @Drdave That is the correct content! I used it to run Cura 3.3.1 and it works here (on my MacBook). I also see you have some plugins installed, it might be that your Octoprint plugin needs an update.
    To get Cura running again you could try to delete the folder OctoPrintPlugin:
    1948183739_ScreenShot2018-05-02at07_49_46.thumb.png.b74e62217608aa793ceccf0e9ad179fb.png
    When Cura runs again you can redownload it from the plugin browser.
    Bummer that didn't work either
    Anyone else having this non-install issue?
    Help Msuurmond by posting your copy of the installed 3.2 folders so they can review the difference between working ones and broken ones
    Dr. D
    Dr Dave,
    The only luck I have had was to delete the 3.2 & 3.3 folder. Opening Cura accepting all the popups then closing out and replacing the 3.2 file in the deleted location from the trashbin.
    19 minutes ago, Preston3 said:
    Dr Dave,
    Preston
    That is what I reverted to as well
    The only problem is that I can't get Windows to default to the 3.3 version upon clicking on an STL file so I have to open the 3.3 manually then drag and drop otherwise it opens the file in 3.2
    Have tried to rename the 3.2 and the like but then I get a Win10 error talking about a pathway error occurring
    I am OK with it I guess the added features of 3.3 are worth it but this dang software is SO buggy I can't for the life of me figure out why
    I had a similar issue when we all started on 2.0 or maybe 2.5 or so
    NOT sure why the install doesn't simply copy the entire contents of the previous version instead of asking to remove the older versions.  I have LOTS of medical software that we run concurrent versions of why not Cura?
    Thank you for taking the time and if anyone figures a viable fix let me know
    Awaiting another version with still more great new features
    Dr D
    Posted (edited) · Printer and material profiles lost 3.2.1
    Grr!! Having this issue again this year (had it last year during another upgrade).I am a UM3 / OS X user.
    I just upgraded to 3.3.1 and having the issue of all profiles disappearing. I tried deleting all directories in ~/Library/Application\ Support/cura, launching Cura, in the configuration wizard that pops up I tell it I have a UM3, and tell it to connect to my printer. The preferences window automatically pops up, and at this point I DO have profiles in there. I can even exit Cura and reopen and they are still there. But the moment I go to upper right, click the dropdown to select my configuration, the profiles disappear.
    (This animated gif begins where I am opening preferences and you see the profiles exist)
    Screen%20Recording%202018-05-25%20at%200
    Edited by Croy9000
    I am attaching a file that has the section of my cura.log that captures the moment I click to select my configuration.
    This area looks notable (but maybe not related?)
    2018-05-25 15:42:53,215 - INFO - [MainThread] cura.Settings.MachineManager._updateQualityWithMaterial [1144]: No available quality types found, setting all qualities to empty (Not Supported).
    2018-05-25 15:42:53,217 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [15]: Updating CustomQualityProfilesDropDownMenuModel.
    2018-05-25 15:42:53,219 - INFO - [MainThread] cura.Machines.QualityManager.getQualityChangesGroups [186]: Cannot find node for machine def [ultimaker3] in QualityChanges lookup table
    cura.log
    Edited by Croy9000
    cura.log
    Could you share your whole config folder as a zip-file? Than we can use that to reproduce it on our development machines.
    @Msuurmond I have shared 2 zip files (renamed to 3mf to get them to upload). cura-before is ~/Library/Application Support/cura right after deleting all files in that directory and relaunching Cura so it populates it with clean data. cura-after is after the profiles go missing as described above.
    cura-after.3mf
    cura-before.3mf
    cura-after.3mf
    cura-before.3mf
    Hi @Croy9000, I have checked your video. Turns out that the missing profiles was caused by the machine settings. I took a screenshot of your video and highlighted the part:
    The combination of empty material together with BB 0.4 doesn't have any supported profiles. That's why you see no profiles in the list.
    To solve this, you can disable the 2nd extruder since it has no material there: right-click on the 2nd extruder and choose "Disable Extruder". This way the profile list will only take into account the 1st extruder when it tries to find suitable profiles.
    To enable the extruder again, you can right-click and choose "Enable Extruder".
    @lfei WOW! Thanks for that find. I confirmed what you said works. I also placed my AA core in that #2 slot and it does not have the issue either.
    Was this a regression with 3.3.1 though? 3.2 did not have this issue.
