Good job Travis7i!
I also had some success:
It's not perfect, and it's useless because the layers aren't in the right orientation but I got a complete nylon print!
I used the 0.25mm nozzle, set the build plate temperature to 100C, printed a dummy cylinder around the part to wipe the nozzle and cancelled z-hop to avoid stringing.
Thanks for all of your inputs.
Coalwater 1
I'm using Ultimaker nylon. The default speed is 70mm/s. I've tried 35mm/s. No difference. I'm still trying to dial in that ooze shield, that's the closest I've been to success...
