Thanks for responding ahoeben.
I have just changed the GCode setting to "Marlin" and seen that it enables diversified settings for temperatures.
One question left, now the GCode setting is changed from Ultimaker to Marlin, is this GCode still compatible with my Ultimaker 2 + Olssen Block?
How to control temperature settings through Cura 3.2.x on Ultimaker2?
Yes, it is still very much compatible with the UM 2 with Olssen Block, but changing the material type on the LCD panel will no longer affect the print; the temperature, flow & cooling options set in Cura override whatever you set on the printer.
- 1 year later...
And if it's allready set to Marlin?
Then you can edit temperatures in the Custom settings.
ahoeben 1,886
Go to the Printers pane of the preferences, press Machine Settings, and in the dialog that opens set the GCode flavour to "Marlin".
