Have you checked the actual diameter of your filament? (Determine at several places in 2 directions (90°). I once had a woody filament that was only about 1,6 mm despite its declaration of 1,8 and it also under extruded for this reason. Giving Cura the actual diameter of the filament fixed this issue.
Other than that, I guess it could be that your teflon coupler needs replacement.
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
Tafelspitz 5
