Not getting Squareness
3Vima
Posted · Not getting Squareness
Hi every one,
Can anyone suggest how to get squareness on prints? Currently, I am printing PC material and not able to print it perfectly.
It's getting radios on outside walls instead of the straight wall.
    Posted (edited) · Not getting Squareness
    @SandervG can you please help us
    Edited by 3Vima
    We can always try :)
    What firmware are you using? It can be that your jerk and acceleration settings are sub-optimal.
    How tight are your belts? And at what temperature are you printing (print head & bed)?
    Its brand new machine. Belts are good and tight enough. Print temperature 280
    Bed temperature 115
    I would still recommend to see if newer firmware is available. Is your Ultimaker 3 connected to the network? If your Ultimaker spent some time at a reseller or in a warehouse, it is possible that a new firmware is released in the time it left our assembly factory, and ended up at your doorstep :)
    280ºC seems on the high side of things, could you try to reduce it to 260ºC?
    But your radius doesn't seem that bad, does it? I put a ruler over your photo, and they seem pretty straight to me. radius.thumb.png.a69d02298354b8594a4fa5bfb5179865.png
    I will get back to you with new photos. I will try it again with reduced acceleration to 2000 instead of 4000.
    Thanks for your help
        • 6 replies
