Wall thickness calculated wrong
Posted · Wall thickness calculated wrong
Somhow the numbers do not match:
line width= 0.4
wall count=3
wall thickness =0.7???
The thickness is graied out and does not seem to change when changing wall count or line width.
What is wrong there. I am using current version of Cura on a mac. I
    Posted (edited) · Wall thickness calculated wrong
     OK, I clicked on the! Next to wall line countc and set it back to an automatically calculated value. Then the wall thickness was unlocked. Now setting the walls thickness three times the line with brought the wall kine count back to three but now showed the right wall thickness. Print is running and we will see if that solved the problem.
    This post brought me on that track:
    Edited by NozzleMover
    Link added
    It seems to me that either I am asking the wrong questions or no one is actually in this forum.
    Nevertheless:
    I change the wall thickness to 1.05 and Cura shows in layer view 6 lines for a 2.1 mm part using a 0.35mm nozzle.
    Results look still strange. Outer wall is sometimes missing.
    Anyone an idea?
    With Slic3r the exact same part, with the same settings, prints right.
    Come on Cura-guys! The problem I described above is truly a problem in Cura. You should be interested in fixing that.
        How to Enter
        Design an Ornament
          Entering a new design
        Entering an existing design
        Winning designs should:
        Be original Creations
        Good luck 🎉
        • 1 reply
        • 17 replies
