Hi
So .... to get back to the top of this ... what is needed is a Cura "something" that can put in a pause based on filament used. More or less, tell it that I want to stop before 740g and let it figure out the best point. If this is a bigger printer, something like that will be needed. Since I *know* that a 1,200 g print will run over a 750 g spool, I need to do something. Sitting and watching the spool is a really boring thing. Ask me how I know this
Bob
Edited by uncle_bob
Top Posters In This Topic
89
40
38
36
Popular Days
Apr 23
76
Apr 19
32
Nov 2
31
Apr 26
30
kmanstudios 89 posts
SandervG 40 posts
Shadowman 38 posts
uncle_bob 36 posts
Popular Days
Apr 23 2018
Apr 19 2018
Nov 2 2018
Apr 26 2018
Popular Posts
Daid
Problem was that dilithium was very difficult with legislation, being an accidental space-time warp risk. So we removed that feature last second.
Daid
It's bigger. 330x245x315mm to be exact. And that volume can be used by BOTH nozzles. No more less volume for dual extrusion prints. It has a flow sensor, that works for jam detection as we
foehnsturm
As for the flow sensor. We (the Mark2 crowd ) almost finished development for an external flow sensor for the UM2+ including firmware integration. Mechanically it fits to the UM3, but connecting to e
Posted Images
Daid 305
Well, how bad is a small scar on your model compared to a failed print because filament ran out? Yes, resuming isn't 100% smooth sailing, but the current UM3 firmware already does some smart tracking of filament positions to allow material changes during a print and resume as good as possible. As it tracks how far the material is retracted when pausing, and puts the filament tip back at that position when resuming the print. That's generally where things can mess up, filament all the way at the tip, while the gcode thinks it is retracted, you will get a messy result :-)
Oh, and you can program in pauses into UM3 gcode as far as I know. M0/M1 should pause the printer in the UM3.
