thanks for the fast reply : )
i print with original UM pla.
the bottom (1cm) shows the inside change of the object. it goes from solid to hollow after about 1cm.
The settings are close to standard. I changed :
the z seam alignment to random
infill to 80%
optimize wall printing order enabled
first layer temp to 200°
top / bottom pattern to concentric
Printcore is the standard 0.4
modelled with fusion360
thanks in advance.
Edited by sutter
SandervG 1,522
Hi @sutter, thank you for your post and welcome to the forums!
What filament are you using? And what print core? Have you used other materials in that print core as well?
The bottom also doesn't look great. Do you use default Cura profiles?
