maybe. Possibly. Retract distance is too large. Try 4mm in S3D.
One tip I’ve had luck with...
In Cura, go to your machine settings and set to Marlin. Then in Cura you can see the speeds , retract distance and so on
For my UM2+ I set the retract distance to 6.9 and matched things up from there.
Overall I find Cura does OK. The latest Cura I did a print with had a few problems so I went and did it again in S3D.
Edited by LePaul
ctbeke 132
This is because Cura is fully optimized for Ultimaker printers and we spend a lot of time tweaking the default profiles. Simplify3D is not, you're on your own in that software (unless someone in the community has a nice profile for it).
