Stringing at ultra fine layer height
Tiger91
Posted · Stringing at ultra fine layer height
I'm trying to print a vase scaled to 50%.  When I do so at a .06mm layer height, there is stringing at the hard edges.  I've tried to change the temperature and speed, but haven't had success making it somewhat clean.  How do I make it work?
Using ultimaker 3, updated cura, with white PLA
HexagonVase.stl
    Could you show a photo?  It must be a strangely shaped vase to get stringing.  In general I get zero stringing.  Zero.  I print slow and cool.  On UM3 usually 30 or 40mm/sec on outer layer.
    I uploaded a photo - it was actually a bit worse as I had scraped some of the stringing off earlier.
    Ooh yes yeugh. Try any or all of  all print speeds set to 30mm/s (1st layer 20mm/s)   Fan 100%  extruder temp; with layer height of .300 the probably no higher than 200 - cooler if layers are thinner; assuming a .4 nozzle then line width .4 and wall size a multiple of .4        I assume you are not using spiralise.
    Not using spiralize.  I would like to do it at .06mm and have it work.
    No reason why you cannot use .06mm; I suspect you would not want to go above 190 but I have little experience at that thinness. Also I have no understanding on whether really thin layers have any impact on stringing
