How to Enter
Design an Ornament
Entering a new design
Entering an existing design
Winning designs should:
Be original Creations
Share the creative journey! Include documentation of your design process, giving us a peek behind the scenes. For example, show a screenshot of the model in your design program. Use the Tag Holidays2023.
Make sure your submission aligns with our guidelines and Thingiverse's Terms of Service.
Good luck 🎉
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
tinkergnome 926
The pre-compiled hex-files are allowing up to 300°C as nozzle temperature.
If you import a MATERIAL.TXT file with higher nozzle temperature, this becomes the new maximum. Use it at your own risk...
Steps/mm and rotation direction for all axis can be adjusted on the printer (Advanced -> Preferences -> Motion settings)
If you still have a need to compile it yourself, have a look at the "cookbook" that @gr5 made
(including links to the source repositories at GitHub):
How to build Marlin the way tinkerghome and Ultimaker do it if you have windows
