Posted · Printing round models
Can you share some details about your printer, nozzle size, filament, print settings etc?
It would also help to see this print in the position it was oriented on the plate.  The gaps appear to be at their maximum nearly 180 deg apart.
For example, if this was an UMO, I'd check the xy stepper belt tension first, then move up to the larger belts, and go from there.
John
    Thanks for the reply John
    printer wanhao duplicator v2.1/ 0.4 nozzle/ PLA /Cura 3.1 0.2-brimm 0.8-wall 0.8-top/b0.8-comp wall overlaps-hide seam-infill 20--retr 1.5-cooling-speed 60 mm/s
    pos see picture
    im chekking belts/stepper
    report back if there are results
    wr Henk
    have checked every bolt
    a more closer look shows a mistake in the print direction at 4 places
    see image
    now i think that the y axis stepper motor skips steps at direction change
    have ordered a new one
    fingers crossed?
    Well, if changed the stepper but no(the same) result
    Dont know were to look now for a sollution?
    Wr Henk
    found an old post
    that pointed me in the right direction https://community.ultimaker.com/topic/19494-circles-are-not-fully-round/
    my x / y frame was not 90 degrees square
    have tacled this  with braces and the print result
    is finally good
    w r Henk
