Ultimaker Cura 3.3 is available from today!
Following the news from yesterday, a large part of the news relates back to the Ultimaker S5.
Among others Cura can now also create a UFP.
UFP (Ultimaker format package) is a new file extension that contains compressed gcode and a preview thumbnail. Using this extension enables a model preview (similar to the solid view in Ultimaker Cura) on the Ultimaker S5 touchscreen and in Cura Connect.
Since we also introduced a new material, 'Tough PLA' yesterday, the material profile can now also be found in the latest Cura version.
Tough PLA prints as easy as regular PLA, except it is as strong as ABS. Which means if you are looking for strong prints it is definitely a material worth exploring. The prints with the same temperatures as PLA, which implies it is equally heat resistant.
Besides aligning Cura with the recent expansion of our product range, we have also added some new features.
Ultimaker Cura is now equipped with a 3D model assistant. The 3D model assistant triggers when you want to slice with ABS, PC, PP or CPE+ and can give you tips on how to potentially improve the quality and reliability of your 3D print.
- More good news is that you can now also easily do single extrusion prints, when your model allows it.
Using single extrusion mode also makes the ‘print one at a time’ feature available for the Ultimaker 3 and Ultimaker S5. You can easily disable it by right clicking on extruder 2 and enable/disable it from there.
- The prime tower has now been made round instead of square, which should result in a smoother toolpath and a sturdier prime tower.
- Support blocker also made it into the stable version. @ahoeben , thanks again! You can now generate a cube mesh to prevent support material to be used in certain areas within a model. Each cube can be scaled, rotated, and moved with the standard adjustment tools in the left side of your screen.
- Bridging. Many thanks to @smartavionics . It is still a fairly new feature, but it allows Cura to check for bridges and opens up more configurations to tweak for better briding.
Finally; three new plugins have been added; Scalable extra prime, Print temperature offset, and Enclosure fan.
I've mentioned some already, but I want to thank everyone for there help in realizing Ultimaker Cura 3.3. We couldn't do it without you!
I'm talking about @ahoeben , @smartavionics , @thopiekar , Pheneeny, krios-fabteam, dagoma3d, uBuild-3D, maukcc, timur-tabi, pouncingiguana, velbn, and Gordo3di.
We've also created a 6-minute video where we go a little bit more in-depth regarding some of the improvements of Ultimaker Cura 3.3.
Can't wait?
Download Ultimaker Cura 3.3 here! Not entirely convinced yet?
You can read more about these features and more on our blog!
Looking forward hearing from you, and make sure to share your feedback with us. That is the only way we can continue improving on this wonderful slicer!
