I thought that too but in Simplify3D the Skirt line went all the way around too.
Here's the Thingiverse link, you do have to rotate the model for printing.
https://www.thingiverse.com/thing:2753581
No, the bottom is not flat. You can sink the model a tenth of a mm or so into the buildplate, and then the skirt will draw as expected.
I think this video on cleaning the nozzle is a better alternative to a skirt
Edited by MarkF
I know this is an old topic.. and I still haven't installed the _latest_ Cura (running on 3.3.1 right now) and I just got _this_ weird skirt.. first time _ever_. If I change to brim, it's placed correctly around the model. I'll install the latest update and see if it does better ?
Quick update: rotating my model 90 degrees around the Z-axis results in a correctly placed skirt..
Edited by renelm
Looks like the bottom is not flat.
ahoeben 2,047
How sure are you that the bottom is flat? Can you share the model?
