THX so much GR5 for your response!
I did see this video before and since I just purchased the UM3 a couple weeks ago, I would like to avoid voiding my warranty if possible. The crazy thing about my printer and my two AA .4mm cores is that they have now both had this issue. I had the backflow problem 1st couple of days and MatterHackers asked UM to replace a defective core with a new one. Now a second one has failed? Over extrusion issues? In other words, does my printcore 1 over extrude filament? it would explain why my prints don't fail but the extra filament has to go somewhere? I am absolutely torn on the subject and wish I could find the answer to this problem to eradicate once and for all. Is my extruder 1 the culprit? No idea....
Cheers,
Olivier.
gr5 2,099
It looks like you have a leak just above the block. Or did that come from below the print head? I can't tell without seeing if your print failed before this happened. But I'm leaning towards the fact that you have a leak.
You should contact your reseller and get a new one. Or if you are too shy do do such a thing you could (as a last resort?) try to fix it yourself. It's VERY delicate but this video will show you where it can break easily and how to take it apart and tighten it without breaking anything:
AGAIN - THIS WILL VOID YOUR CORE WARRANTY
