kmanstudios 1,120
2 hours ago, MarkF said:At least fix Cura so the touchpad works as stated in the documentation. Currently, the CTRL button does NOT work. I was just suggesting you drop the click portion for touchpads.
This should follow as workable in the docs. Ergo, interface continuity of a sort.
1
- 2 weeks later...
It's very annoying to swap hands on the touchpad to switch between pan and rotate. I thought FreeCAD was a better implementation and the ALT key was not being used by Cura.
Plus a left cllick ends up selecting the model half the time instead of panning. Just holding the SHIFT or ALT key with a mouse move would avoid it.
Also, the view rotate seems to rotate around the viewpoint instead of the object/print bed. Hence, rotation tends move the object outside the field of view.
Edited by MarkF
- 5 weeks later...
NO DISCUSSION? NO SUPPORT?
Either, I'm the only one using a laptop with just the touchpad?
Or, I'm the only one that finds the view control cumbersome?
kmanstudios 1,120
I would think that maybe the majority is attaching a mouse? That is just a guess. But keep at it. I do believe it is worthwhile as who knows how many people decided to not use it because of that very reason.
- 4 years later...
The feature exists. It is Space+drag.
No idea why can't it be also Ctrl+drag.
- 1 year later...
- 3 months later...
It's actually simple,
Zoom in/out = 2-finger drag up/down
Rotate left/right = 2-finger drag left/right
kmanstudios 1,120
Here is the problem: Everybody wants their mouse commands to be like the mouse commands from whatever package they use most. That is a lot of things to pound into one interface.
I would rather fix continuity issues as well as focus on making cool stuff. The only thing I would like in this area of mouse control is hooks into the 3D mouse so I could unify all my programs interface navigation. I use several programs all the time. And, it is not easy to get used to interfaces. Even after all my years I still get lost on which program I am working within.
But, until 3D mouse support, make the other, really cool things happen
MarkF 2
ahoeben 2,047
Ctrl+click selects individusl models inside a group.
