Posted · Cura 3.3.1 is Crash!!!
I updated to Cura 3.3.1 .
But I always run into software crashes.
Everything works fine before I have loaded my old JSON file.
Since I put in the old JSON file, the software could not be opened.
The error message is as follows:
Traceback (most recent call last):
File "<frozen importlib._bootstrap>", line 969, in _find_and_load
File "<frozen importlib._bootstrap>", line 958, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 664, in _load_unlocked
File "<frozen importlib._bootstrap>", line 634, in _load_backward_compatible
File "__startup__.py", line 12, in <module>
File "Console.py", line 24, in <module>
File "X:\3.3\build\inst\bin\cura_app.py", line 141, in <module>
File "X:\3.3\build\inst\lib\python3.5\site-packages\cura\CuraApplication.py", line 652, in run
File "X:\3.3\build\inst\lib\python3.5\site-packages\cura\Machines\MaterialManager.py", line 107, in initialize
KeyError: 'GUID'
The log is as follows:
Thread 0x0000266c (most recent call first):
File "X:\3.3\build\inst\lib\python3.5\site-packages\UM\Backend\Backend.py", line 155 in _storeStderrToLogThread
File "threading.py", line 862 in run
File "threading.py", line 914 in _bootstrap_inner
File "threading.py", line 882 in _bootstrap
Thread 0x000018c4 (most recent call first):
File "X:\3.3\build\inst\lib\python3.5\site-packages\UM\Backend\Backend.py", line 147 in _storeOutputToLogThread
Thread 0x000019b0 (most recent call first):
File "C:\Program Files\Ultimaker Cura 3.3\plugins\USBPrinting\USBPrinterOutputDeviceManager.py", line 66 in _updateThread
Thread 0x000021d0 (most recent call first):
File "threading.py", line 293 in wait
File "threading.py", line 424 in acquire
File "X:\3.3\build\inst\lib\python3.5\site-packages\UM\JobQueue.py", line 86 in _nextJob
File "X:\3.3\build\inst\lib\python3.5\site-packages\UM\JobQueue.py", line 116 in run
Thread 0x000003c4 (most recent call first):
Thread 0x00001f74 (most recent call first):
Thread 0x00001490 (most recent call first):
Thread 0x00002214 (most recent call first):
File "threading.py", line 297 in wait
File "zeroconf.py", line 1569 in wait
File "zeroconf.py", line 1153 in run
Thread 0x00002164 (most recent call first):
File "zeroconf.py", line 1017 in run
Thread 0x00001308 (most recent call first):
File "zeroconf.py", line 946 in run
Thread 0x00001408 (most recent call first):
File "threading.py", line 549 in wait
File "C:\Program Files\Ultimaker Cura 3.3\plugins\UM3NetworkPrinting\UM3OutputDevicePlugin.py", line 274 in _handleOnServiceChangedRequests
Thread 0x00000810 (most recent call first):
File "C:\Program Files\Ultimaker Cura 3.3\plugins\RemovableDriveOutputDevice\RemovableDrivePlugin.py", line 61 in _updateThread
Current thread 0x00000ea0 (most recent call first):
File "X:\3.3\build\inst\lib\python3.5\site-packages\cura\CrashHandler.py", line 364 in _logInfoWidget
File "X:\3.3\build\inst\lib\python3.5\site-packages\cura\CrashHandler.py", line 214 in _createDialog
File "X:\3.3\build\inst\lib\python3.5\site-packages\cura\CrashHandler.py", line 82 in __init__
File "X:\3.3\build\inst\bin\cura_app.py", line 101 in exceptHook
Please help me solve this problem. Thanks very much~~~
I need this old JSON file to use my 3dprinter.Thanks very much~~~PLZ
    This is My old JSON file .
        "id": "freedmake",
        "version": 2,
        "name": "FreeDMake v1.5",
        "inherits": "fdmprinter",
        "metadata": {
            "visible": true,
            "author": "na",
            "manufacturer": "na",
            "category": "Other",
            "weight": 4,
            "file_formats": "text/x-gcode",
            "icon": "icon_ultimaker.png",
            "platform": "freedmake.stl",
            "has_materials": true,
            "machine_extruder_trains":
                "0": "blooming_1st",
                "1": "blooming_2nd"
            "first_start_actions": ["MachineSettingsAction"],
            "supported_actions": ["MachineSettingsAction"]
        "overrides": {
            "machine_name": { "default_value": "FreeDMake v1.5" },
            "machine_width": {
                "default_value": 240
            "machine_height": {
                "default_value": 220
            "machine_depth": {
                "default_value": 150
            "machine_center_is_zero": {
                "default_value": false
    		"machine_heated_bed": {
    			"default_value": true
            "machine_nozzle_size": {
                "default_value": 0.4
            "machine_nozzle_heat_up_speed": {
                "default_value": 2
            "machine_nozzle_cool_down_speed": {
                "default_value": 2
            "machine_head_with_fans_polygon":
                "default_value": [
                    [ -43.5, 51.6 ],
    				[ -43.5, -60.1 ],
    				[ 43.5, 51.6 ],
    				[ 43.5, -60.1 ]
            "gantry_height": {
                "default_value": 17.5
            "machine_use_extruder_offset_to_offset_coords": {
            "machine_gcode_flavor": {
                "default_value": "RepRap (Marlin/Sprinter)"
            "machine_start_gcode": {
                "default_value": "G21 ;metric values \nG90 ;absolute positioning \nM82 ;set extruder to absolute mode \nM107 ;start with the fan off \nG28 X0 Y0 ;move X/Y to max endstops \nG28 Z0 ;move Z to min endstops \nG1 Z15.0 F1000 ;move the platform down 15mm \nG92 E0 ;zero the extruded length \nG1 E8 F300 \nG92 E0 \nG1 F1000 \nM117 Printing..."
            "machine_end_gcode": {
                "default_value": "G0 Z223 F400 ;Send Z axis to bottom of machine \nM18 ;Disable steppers \nM104 S0 T0 ;Cool down Extruder 1 \nM104 S0 T1 ;Cool down Extruder 2 \nM109 S0 \nG162 X Y F2500 ;Home XY endstops \nM18 ;Disable stepper motors \nM72 P1 ;Play Ta-Da song"
            "machine_extruder_count": {
                "default_value": 2
    		"machine_disallowed_areas": {
                "default_value": [
                    [[-120, -75], [-120, -56], [-108.5, -56], [-108.5, -75]],
    				[[120, 56], [120, 75], [108.5, 75], [108.5, 56]]
            "prime_tower_position_x": {
                "default_value": 195
            "prime_tower_position_y": {
                "default_value": 149
