There is an option in the General preferences now that will at least stop Cura from crashing by forcing it to start up on the primary screen. The caveat is that you need it to start at least once; temporarily disabling the second screen should work with that.
In the General settings, uncheck the "Restore window position on start" checkbox.
ahoeben 1,654
You are not alone in this, but this issue is proving hard to reproduce for the developers:
https://github.com/Ultimaker/Cura/issues/2226
Carbuns 0
This is still an issue in 2020 with 4.6.1. I'm quite sure it has to do with the fact that one of the monitors runs with the integrated intel UHD graphics 630 card, and the second one with the dedicated GeForce GTX1060, but I still couldn't find a way around it. I tried changing the graphics card cura uses or disabling the integrated graphics card, but none of them worked for me. When it opens on the wrong monitor there is no way around it other than closing it and opening again with only one display.
