at first i also thought that i put the plate to far away from the nozzle, but after recalibrating it with the paper i noticed that the corner at the back at the right was the highest point and i nearly didn't get the paper between the nozzle and the plate. (which is strange because i know i didn't do that bad of a job at calibrating)
i will give the hair spray and wood glue a try.
I also just remembered that the previous 2 prints where printed with a layer heigth of 0,1 and that i am now trying to print with 0,06.
gr5 2,095
Your plate is too far from the nozzle on the right side. Turn that screw (right screw) one full turn CCW from below to move the plate up. Turn the other 2 screws 1/3 turn CCW also.
Also I recommend some kind of PVA glue. You can get away with no glue sometimes and with smaller parts but you should put on a thin layer of glue. There's 3 excellent ways to do this - one way is to use the supplied glue stick and use it sparsely (don't cover the whole bed) then spread it around with a wet tissue to remove most of it and to spread it very thin. Alternatives: hair spray, wood glue mixed with water (1 part wood glue, 10 parts water) spread with paint brush. Wait for it to dry.
