The grid shader bug never had anything to do with settings or writing gcode. You seem to have uncovered a new bug that I at least have not seen reported before (especially the gcode bit)
1
Just now, ahoeben said:The grid shader bug never had anything to do with settings or writing gcode. You seem to have uncovered a new bug that I at least have not seen reported before (especially the gcode bit)
Is there a way for me to post a log of Cura for someone to take a look at? I've seen others do that in similar discussions, but I'm not totally sure how to pull the logs
In Cura, go to Help -> Show configuration folder.
The folder that opens should have a Cura.log file in it. It is probably large, too large to attach here. So please upload it on some cloud storage platform and post a link.
Note that I am not an Ultimaker employee, I just contribute to the Cura project. The best way to get the developers attention is to post an issue here: http://github.com/ultimaker/cura/issues
Wcj97 0
Also, in case this helps a diagnosis, Cura has been freezing when saving a gcode file for my new printer profile. It seems to slice fine, and actually saves all of the print gcode, but freezes towards the end of the save so that my gcode file does not have my 'end gcode' written. This means when my printer finishes the print, it does not lift the z, or home, or even shut off the hot end - it just stops right where it read the last line of gcode in the file. Seriously this is all becoming super frustrating.
