And you probably want to go for the 0.25mm nozzles for your small prints. They're capable of achieving really fine results. Your extrusion volume will be a little bit lower (because smaller nozzle) but the quality will be really good. And for a small print the lost speed will probably still be acceptable
Advices for a new printer
Thanks to everybody for the answers!
And how about to print ABS with the 2+ ?
I never tried with mine, I only know that is more complicated
fbrc8-erin 316
I think the UM2+ is really reliable and easy to use. It's an absolute workhorse. Pretty much the only calibration it needs is for you to level the bed correctly when you switch out nozzles or glass plates. Other than that, it basically should just work.
