fbrc8-erin 270
Line NR errors (Line Not Read) is most often the result of a corrupted file on a USB stick due to unsafe removal from the computer. Reformatting the USB stick usually does the trick in that case.
Were all of these error message on 1 file, or multiple files?
One printing method? Or multiple printing methods? (i.e. did you try USB, and then try LAN/wifi when USB didn't work?)
1
gr5 2,095
Did you look at the gcode file? Just take a look at it.
