Thank you. I tried that and found my project files were greyed-out in the list, implying they weren't in a supported format. When I looked closely I found they had not been given the .3mf extension! I have to manually put the .3mf extension at the end of the project files I save, then it works.
At least I can save and open projects now so thank you.
ahoeben 1,886
You open projects with the same File -> Open... command you use for opening meshes.
When you open a project, Cura asks if you want to open it as (a collection of) models, or as a project.
Note there’s a preference in General preferences that may suppress the aforementioned question.
