To reiterate. I have spent two full days (well over 10 hours) trying every possible combination of height and temperature, speed extrusion rate and others. If it was a bed height problem I would have solved this in the first ten minutes. I have used this machine for well over 2 years and I have manually leveled it hundreds of times and the only thing that has changed is the control board. Turning the speed down to 5 mm/sec seems to indicate that the extrusion starts a little late but that still does not explain the dragging. I have even messed with firmware retraction.
Okay well it's happening all over the place but always at the start (or is it the end) of each hexagon so I guess I believe you (mostly).
Do you have a feature called linear advance or something advance turned on in your printer firmware? That retracts a bit just before you get to a vertex that has a retraction or a major change in direction which would happen at the end of each hexagon if you have this firmware feature.
WAIT - you said it happens at the START of each hexagon.
So maybe the problem is that it is *not* retracting when it moves from hexagon to the next and leaks a little on the way so it starts out underextruding (combined with what looks to me like the head is a bit too far - I like to really really squish - much more than you are doing here). I'd try turning off combing for the first layer - something like "no combing initial layer". It's in the combing drop down I think. This will force it to retract when moving from one hexagon to the next and not leak any on the way.
So I think it's a combination of 2 things: not retracting, head too far from build plate. Fixing either thing should fix this I hope. I know you disagree but when the filament doesn't stick it always means you don't have enough filament getting squished into the plate so it's either some kind of underextrusion or nozzle needs to be closer (or both).
Hmm.. This is a good place to start. I was using an old version of cura for a long time and did not have this option. I was surprised to see it "avoiding parts" and did know why. Additionally I have been messing with retraction but I seemed to be that I could not induce a change and this explains this as well. I can not currently run retraction to any extent because my Teflon tube went missing.
That worked! (stupid combing)
Ok... so it's a little better. I'm still fighting like crazy. It's acting like there is a .01 margin of error for where the print head is happy but there is a .05 error in the print bed so there are places where it is fine and places where it is not
gr5 1,872
This is trivial to fix on most printers - the problem is your nozzle is too far from the build plate. On an Ultimaker for example just turn the 3 screws CCW about 1/2 turn and this will stick just great.
If this is a printer where you can't disable autoleveling then I don't have any suggestions.
