Posted · Strange top surface pattern
Hi, any UM2+ user encouter the surface printer issue indicated in attach photo?  the repeative pattern happen on every print, this should not be caused by bluid plate not flat, because same problem also happen on top surface on high object.
    Fluctuations in temperature, in cooling, or in filament diameter? If it were bent rods, I would expect the pattern to run horizontal or vertical, not diagonal. Or a dirty feeder wheel causing uneven feeding? Just guessing...
