Hmm, don't understand that, perhaps @ahoeben can help?
This is (obviously) not the way it is supposed to happen. Picking the "depth" of the location on the screen where you click seems to go wrong. I don't yet understand why this happens exactly, but it has been reported by a small handful of users. What GPU do you use?
Hi ahoeben!
It's just Intel's HD 4000.
Can I perform any user test for you? I'm very eager help ?
Thanks, that helped in reproducing the problem. I will try to fix it.
6 minutes ago, ahoeben said:
Thank you for such a quick response!
I'm glad to report that the patch fixed the above problem for me. PERFECT
Thanks for testing it so promptly
burtoogle 509
What I do when it is difficult to click on the underside is simply to click on the side wall of the part and then use the move tool to quickly move the cube to where I want.
