kmanstudios 1,120
I am using white TPLA with the default settings and getting a good looking print out of it.
1 hour ago, chuckmcgee said:Just got my S5 and printed with black tough PLA. While the model was small, the filament was dispensing very thick and goopy...thinking either to reduce the flow rate or the temp. It is currently using default settings as detected by the NFC.
Do most of you find it customary to have to change those detected settings?
Usually you shouldn't. What type of print core are you using, and do you have a photo of the print? And congratulations on your S5 ?
Thank you for the quick reply @gr5 and @SandervG
My first print (maybe not the best) was an antenna cap I designed for my truck. I have a tall antenna that I don't use, so I unscrewed it and use an antenna cap I designed. I decided I would replace the resin one I did on a Form2 with the new S5 with tough PLA (hoping it would hold up to the sun better than traditional PLA).
I used the standard 0.4AA nozzle.
Here is the model in Fusion360 (10mm diameter of the widest part):
Here is the outcome with default settings:
Edited by chuckmcgee
gr5 2,330
I tested their regular pla. I have tested about 20 different brands of PLA and they all get soft around 52C. Unless it is advertised as "high temp PLA" or HPLA (for example proto pasta has such a thing) I doubt it's different.
Anyway it's very easy to test yourself. Set the build plate to 60C and place 5cm of filament on the build plate with a towel over it. After 1 full minute at temperature grab the filament and bend it. At 60C you will see it's soft. Then lower to 45C and then try at half way between 52C and so on until you find the point where it gets soft.
As a general rule of thumb you want to print with the build plate 5C to 10C above this temp so that the bottom few layers can flow slightly (like clay) when under strong stress due to warping stresses. This will help keep your print on the glass. This rule doesn't apply to flexibile filaments such as TPU nor to Nylon which doesn't have an obvious softening point but instead just keeps getting more flexible gradually (so 80C should be enough for nylon but it gets suddenly pliable just a little below the melting point).
chuckmcgee 7
