I figured it out that it is associated with the material CPE+ and that I am using PVA support. I'm not sure why, but it seems to use this "blob" whenever it switches material. I assume it has something to do with the different melting temperatures of the material. Any thoughts?
gr5 1,843
Two thoughts.
1) that is the typical position for a tower. Make sure you turned off the "wipe tower". The new wipe tower is supposed to be round. That really really looks like a wipe tower. You can change it's position as you can set the X and Y position of the tower or you can just get rid of it.
2) If it's not a wipe tower then try rotating your primary part to see if that other thing moves as well.
