PostProcessingPlugIn layer issue
JCD
Posted · PostProcessingPlugIn layer issue
I use Cura 3.3.1 and I try to create a plugIn by modifying the SearchAndReplace.py file
Everything works fine except that there is a problem in the layer "parsing" by the script
In the execute function I add a new line (the last line but one)
    def execute(self, data):
        search_string = self.getSettingValueByKey("search")
        if not self.getSettingValueByKey("is_regex"):
            search_string = re.escape(search_string) #Need to search for the actual string, not as a regex.
        search_regex = re.compile(search_string)
        replace_string = self.getSettingValueByKey("replace")
        for layer_number, layer in enumerate(data):
            data[layer_number] = re.sub(search_regex, replace_string, layer) #Replace all.
            data[layer_number] = ("JCD >>> %d \n" %  layer_number)  +  data[layer_number] # !!!! new line added
        return data
the result on the GCode file is not consistent
At the begining of the file there are 2 "layers"
beginning of the post processed GCode OK
JCD >>> 0
;FLAVOR:Marlin
;TIME:249
;Filament used: 0.194653m
;Layer height: 0.2
;POSTPROCESSED
JCD >>> 1
;Generated with Cura_SteamEngine 3.3.1
;LAYER_COUNT:28
JCD >>> 2
;JCDLAYER:0
then OK (difference of 2 between layer number-postPocess parsing- and LAYER number -slicing-up to LAYER 21
layer 21 OK
;TIME_ELAPSED:215.547436
JCD >>> 23
;LAYER:21
layer 22 not detected ! no new line inserted before the ;LAYER:22 line
;TIME_ELAPSED:222.765224
;LAYER:22
layer 23 OK but the difference now is only one
;TIME_ELAPSED:228.186561
JCD >>> 24
;JCDLAYER:23
 What is the problem ?
jeton27.stl
    just an information, my question is about the "skipping" of the 22nd layer, the first two are useful (introduction and start GCode)
    I've found the same problem on a simple cube
    I changed the height od the cube (hence the number of layers)
    On every try, if the total number of sliced layers is n the skipped layer is always n-4  (100 >>>96 ; 26 >>> 22 and so on)
    I tried to modify the top thickness but it doesn't change anything
    It seems like a bug, so beware if you're postProcessing to check for the ;LAYER:XX line if you're looking for a modification on each layer !!
        How to Enter
        Design an Ornament
          Entering a new design
        Entering an existing design
        Winning designs should:
        Be original Creations
        Good luck 🎉
        • 1 reply
        • 13 replies
