Thanks smartavionics. So the strange thing is that I had quit cura so I just opened it, reloaded the 3mf file and sliced to grab a screen shot. This time it has sliced it in once piece as I would have expected rather than the two L shapes. I can't give you the screen shot that you asked for and my problem is solved, I just do not know how or what could have caused that.
I will give it one more try, currently I seem to get about 8mm high and the hole thing shifts in the Y direction by about 2mm and goes building for a bit longer... The attached is an image of the aborted bracket. The mark halfway up the long side is where the ends of the two Ls were meeting. I have no idea what has caused the Y shift, the model was stuck like s*** to a shovel so the model did not move, for some reason Y just jumped a whole bunch.
burtoogle 509
Hi, please post a screenshot or attach the gcode or 3mf file so we can see what the problem is. Thanks.
