What about the X and Y dimensions, are they correct or off as well?
7 hours ago, SandervG said:What about the X and Y dimensions, are they correct or off as well?
X & Y dimensions are as good as usual (within .010").
14 hours ago, fbrc8-erin said:Is your active leveling on? Is the wrong height the same all the way across the print?
Active leveling makes corrections through the first 20mm of Z-height (if I remember correctly), so if your bed isn't manually leveled well enough, you could end up with it the height being wrong on one end or the other.
Active leveling is on. The part is shaped like this when printed:
¯\__/¯
And the dimensional discrepancy is between the build plate and the ends on both ends. So, yes, it's the wrong height at both ends of the part.
fbrc8-erin 298
