In response to Erin, attached photo shows the offset in the support structure. It occurs at roughly z = 1 1/8 in and 2 1/8 in. There is no offset in the X direction, the surface is smooth at all heights (closest surface) . The offset in the Y direction is about 1/8 inch at height of 1 in and 3/8 in at height of 2 in.
I have heard from someone where I work that I should be looking into "Layer shifting" and that it probably is a lubrication or belt problem. I guess that is the same as "Missed steps" mentioned by Erin.
The coworker suggested that there are max acceleration parameters that I could tweak. They don't show up on the older Cura (15.4)that I use. They suggested that I should update to cura 3 to find these parameters. Any suggestions on which parameters (as I slowly work through the machine hardware issues, printing slower to get it to work).
They also said they had no problem running cura 3 gcode on the Ultimaker 2 printer with older firmware (15.4). Thoughts on this? I suspect all the dual head support and whatnot is for newer printers than Ultimaker 2. Or do I really need to update firmware to match cura version?
Bill
fbrc8-erin 270
Hi, Bill,
To confirm, you're seeing a hard shift like this picture below?
This is a result of missed steps. If the printhead encounters resistance trying to move, the X (or Y) motor will miss steps/lose count and you'll see a shift--the printer counts all its steps based on the home position before printing. Normally if it happens once, I'd go ahead and lubricate your X and Y axes. You may also want to check your pulley and sliding block alignment. Also, when moving the printhead by hand, feel if one motor is giving you more resistance than the other one.
If everything is lubricated, aligned, and your printhead doesn't feel hard to move by hand, it may be a one time glitch and usually doesn't come back. If you start seeing it across multiple prints after checking all of those things, then there may be a bigger issue at play.
